Couple of basic questions first. It's a 55875.
What should the spark plug be gaped to? What is a decent base idle and can you put it in gear and troll around at that RPM (I presume 900-1000ish)?
My motor won't idle. I can start it and it will stay running some 1500 RPM with choke on, but if I turn the choke off, it dies unless I throttle up to some 2500+. If I try to drop the rev, it dies. I just cleaned the carb out with a can of carb clean and clean rag. Fresh gas, new primer bulb, clean fuel filter.
What do I do??
What do I do??
