my 72 100 horse has set up for several years. I changed the plugs crained the gas tank but forgot the fuel line so it fouled the plugs. I drained the line cleaned the plugs hooked up the muffs to the spicket and cranked the motor. it cranked and i ran it on the high idle to burn off the excess fuel. it ran for maybe a minute or two and shut down like i had turned of the key. I checked the fuel pump and its working fine. I checked fire and it looks great. After trying to crank it several times i checked the plugs and they are dry, like I'm getting no fuel. I know the fuel pump is working, so I'm thinking crank seals or reed. I'm leaning to crank seal but would like a more experienced opinion. is there a way to check without pulling the engine down?
thanks
Pat
thanks
Pat
