I have a pair of 6v92ta in my boat. I replaced throttle and shift cables and added a set to a lower station on my boat that had been disconnected. There are 2 identical stations on my boat and each cable runs back to the engine and transmission. I hadn't run the boat up to full throttle in some time and didn't check it before I installed the cables. Now the engines will only run up to about 1600 rpm under a load. There are a bunch of ajustment on each end of the cables. Before I start adjusting those is it ok to try and run the engine in neutral up to wot? I'd like to see if I could rule out any prop or bottom fouling before I start adjusting anything. So I quess I could have just asked is it ok to run them up with no load and if it is how long could I do it? Also is there a possibility of damage from doing such a test. These engines are very intimidating at wot the turbo's scream and the vibration is not for the weak of heart. Looking forward to any and all input. Thanks
