Bathtubbob
I’ve got a 1995 175 J175EXEOM powerhead just rebuilt, rebuilt VRO, rebuilt fuel primer, rebuilt carbs, all new seals and gaskets everywhere. All intake related surfaces checked for warping. All floats including upper fuel bowl are new and set to spec. Engine has 90 psi across all 6 cylinders which will only go up since it hasn’t run long enough to seat the rings yet. Carbs are set at 6 turns out. Stator was replaced with a used one but issue still exists with either stator. Flywheel magnets are good. Plugs are champion oem spec and gapped at .030. Spark was tested with plug on heads and was strong blue. I am pretty stumped at this point but almost convinced it has to be ignition related. Ignition switch was also replaced which helped but this is what I have now. I included a link to a YouTube video since the forum won’t let me upload it to here directly.
https://youtube.com/shorts/BIL3pG72d88?feature=share
