6-71 hard to start
Game Over
I have twin 485hp JT/TIB detroit 6-71.Both engines turn over for approximately 5-10 seconds before firing up when cold(and blow alot of white smoke) if they have,nt been started for about 3 days, although fire up straight away if started within 1-2 days.I'm told it's common although not so sure.I,m wondering if i have a problem with fuel draining back etc.Only had boat for 4months and has been doing it since i bought her.
Any ideas would be appreciated.
white smoke may be caused from cold stuck rings,after engine start and a little heat builds rings come free. try running engines harder on way back to port, may help burn out some carbon.
as for fuel draining back try hooking up a priming pump to filter and pump fuel thr engine pyro to starting to see if it makes a driff.
Hi game over. Can you please post some photos of your twin 485hp JT/TIB detroit 6-71? I really love to see it. :D
Not sure if this worked or not, only have photo of port motor at the moment.
Thanks Marv,
Boat is run at approx 1800rpm for the return to port which can be as little as 1/2 hr although usually more.What sort of priming pump do i use and where do you get them from eg:Mechanic shop, auto spares, hardware etc??.Thanks for your input.
If it were just one engine doing it, I might be inclined to think that the "white smoke" could be steam. But, since it is happening with both engines, it is more than likely raw, unburned, atomized fuel. This will occur on high hour units that have worn cylinder kits or, as Marv suggests, sticking compression rings. Again, since it is happening to both units, it is more likely that they are just equally worn.
You can usually determine that it is fuel just by smelling the smoke. If it is, then you pretty much know that you are not losing prime. Personally, I would not be too concerned about a 5 to 10 second crank up after a long cold soak. I've seen these engines take much longer than that to crank and build heat because of normal wear and still provide good service..
Not sure what is in that turbo inlet housing in the picture. If it utilizes an air filter cartridge then you can"t do what I'm about to suggest without opening it up. But, if it is just a resonator with screen baffles, you can spray a burst of WD-40 into the intake prior to start up to see if that helps the condition.
DO NOT...REPEAT... DO NOT USE ETHER as a starting aid! WD-40 will not damage the engine and ether will...even when used correctly. As a matter of fact, imprudent use of ether will result in the damage that causes long crank times and white smoke. In the business, we call these engines "ether babies" as, ultimately, that is the only way that you can get them to start.
I have the same engines 671 TIB I"m told by a diesel mechanic to drill a hole about one inch above the bottom of the muffler and install a ball valve
into it to release the back pressure to the engine. The muffler holds roughly 2-2.5 gallons of water in them causing the the back pressure along with the drop in temperature. I've done that and have had no problem starting the engines. DAB
I work at a shop that runs all diesel trucks and when they get cold they all have trouble starting. If we do not plug them
in especially in the winter, you might as well forget about getting them started.
The fuel in a 671 is supplied by a gear pump and constantly flows thru the injectors. The fuel not used goes back to the tank but has been warmed by passing thru the head. In cold weather as the fuel in the tank warms, engine efficiency improves. About half the fuel pumped is returned. I don't remember the numbers for your engine, but think the fuel pump moves about 70 gallons an hour. At full power you engine probably burns about 30gph. Detroits are circulating your fuel and it's filtered many times.
When you get near freezing most Detroits can use some help starting. Most marine Detroits have a block heater.
