Got an 03 4stroke 50hp efi not running right. Very rough idle and dies out when throttle applied. Some times it will idle fine when first started for a second or two but runs rough again. I have ruled out bad gas with an external tank with fresh fuel, New fuel filter and bowl ,new secondary filter assy, Spark plugs and wires replaced, Pulled the vapor separator apart and cleaned it. The pump inside the separator is working when 12 volts applied, new tps sensor.
