5.0 GXi-E LP fuel pump
slovelien
My 2005 FW 210H recently became unable to reach full power under load. Now at FT it will only reach 2500 to maybe 3000 rpm. We found some particles on the fuel pressure regulator screen and cleaned it. Pressure in the rail was steady at ~50psi under all conditions. Motor starts right up and idles well. Checked and changed fuel filter, no paint or water found.
Found 0 psi at Low Pressure fuel pump port under all conditions so I believe this to be the cause of the loss of power. Checked for and found voltage to LP harness when key is turned to run position? Plan is to remove pump assy and replace LP pump and check for paint failing in the reservoir.
Assuming this is my issue, how does the failed low pressure pump prevent full power ?
Is there any other thing that I should check?
Low Pressure pump keeps the High pressure pump filled. High pressure pump does not have enough lift to pull fuel from the tank. You are simply running out of gas.
That makes sense in that the HP pump alone can only pull enough fuel from the tank to run at 2500 rpm steady state. Now it’s a matter of determining if I want to disassemble the fuel cell to replace the pump or swap out the entire cell with a reconditioned one from mancavemechanic.com. Appreciate the reply!
Do you happen to know where the LP pump should range? We seem to be having the same problem with our boat. Went through the same checks as you did and when we checked the LP pump pressure we got a reading of 10. So that doesn’t seem to be the issue for us, but we are still back firing when trying to get up onto plane. Did you end up disassembling the cell or just replacing it?
