Did some proactive work over the winer cleaning the HX and oil cooler on my 96 454XLi. The engines were not running hot at the end of last year. Took it out for the first run today and the Port motor is running hot (200 degrees). I'm wondering if I've possibly installed the thermostat backwards? Any other thoughts on what I've done? Water flow appears to be equal from both engines. The other interesting thing about this is that I changed the coolant at the same time, but it didn't appear to me that i replaced as much as I removed - however the expansion tank is full, and when I remove the radiator cap, it also appears to be full.
Thanks for your input.
