kevin_z
It's been awhile since I've posted because everything has been operating as designed!
1995 Crusader 454XL with Quadrajet. Carburetor was rebuilt by Cliffs high performance 2 years ago.
Labor Day weekend went to island and everything ran fine. time to go home and port engine will turn over but not fire. I thought it was fuel pump again, so I pour gas in carb, still no start. got home on one engine and try starting fluid, still no start. Check for spark, no spark. Distributor pick up coil was bad. I couldn't get coil off distributor so i bought new distributor. put it in and we had spark!!!! KA BOOM.
Back fire out exhaust so bad, it blew muffler apart! No injuries and no boat damage. got muffler repaired by fiberglass guy.
Now the question: The engine starts fine and idles. All the gauges are reading correct values. Get underway and above 1500 RPM , engine backfires out the exhaust. pop pop pop
Compression test reads 150psi in all cylinders except #3 and #5. there're at 125psi.
No water in oil, and coolant expansion tank appears to stay at correct level.
What am I looking at? Head gasket? exhaust valve? ect....????
