sandkicker
Outstanding Contributor
Friend's boat... 454 "magnum Bravo" Carbed engine S/N 0C462174... third owner boat... replacing Distributor cap ( T'bolt V)..
Am familiar with the setup up and base timing procedure for 5.7L, however this harness looks different. Can't find a "loose" wire to ground.... There is a wire in the harness near the disti that has a very short jumper back to another wire in the same harness.... Is this the wire??... Can't tell the color of wire since there is black overspray paint on the wires.... IFSO, Did I find the motor locked in the "base timing mode" .... or is it pull jumper to set base timing????
TIA
/Bob
TIA
/Bob
