454 mercruiser water pump
Caliwaterman
Where do i connect the lower hose off waterpump. I connected all the other hoses where i think they should go but this last one has nowhere to go. Maybe i need a t .
I will ask you a question If you can answer it then you are good. I wont tell you the year, or serial number of the engine, carbed or efi, so lets see just how good you are.
I need spark plugs for a 454 mercruiser?
Point it into the bilge and you should be good. Pesky old water...
Its too bad that Jack and o2batsea are not able to be polite and kind to a new member, and leave the sarcasm behind.
A proper response would have been; "we could use more information!"
Actually It is to bad you had to make another useless post and that NO ONE CARES ABOUT YOUR OPINION.
