40hp Johnson top cylinder dead
mebehoof
Hi All,
I've got a 40hp Johnson with a dead top cylinder.
J40ELCDE
Serial#C7203810 Canada
So I think it's a 1986.
Compression: Top 110psi Bottom 105psi Cold
Had to replace the Primer Solenoid as it leaked.
New Plugs
Lots of spark, tested with spark tester. When it's running I pull the bottom wire it stalls, then I pull the top wire it keeps running.
Checked float bowl on top carb for fuel, pulled the drain screw and fuel came out.
When it's running I choked the top carb by hand no rpm change, when I choke the bottom carb by hand it stalls quickly.
While running I brought up the rpm's above idle speed and sprayed some 2cyl raw gas into top carb with no change in rpm or any indication that it saw the fuel.
So, what I've got is good compression, good spark, fuel available but a dead top cylinder???
This is driving me a bit crazy. Has anyone else experienced this situation? Is there something I'm failing to look for? I look forward to any help and thank you for taking the time to read my questions.
Mebehoof
If it is spitting fuel back thru carb or you can fuel low vacuum pull on hand its either a reed or piston problem.
