Returntrip
Hello everybody, Im looking to build a 383 stroker from a running 350ci chevy im removing from my boat. I would like to achieve around 375hp with a decent low, to mid range torque curve. I was hoping to use a set of 906 heads i already have, but i have no problem buying new, either cast iron or aluminum. IM leaning towards a roller cam with close to .500 lift with low 200's duration & around 112 overlap. Ive heard i should be concerned about Quench??? and piston type and selection of lower end components. Im also having a hard time finding a machine shop in the massachusetts area to even talk to about it. Is there anybody that could help me with choosing the right components to build this engine & what i should tell the machine shop what i would like to have done? Or even a book about the build with specs?
Im a little weary of buying an engine from one of those on-line advertisers. maybe someone knows a place to buy a good long block and i would go that route. Im working with around a 4,500 to 5,500 dollar budget. Any info would be helpful. Thank you.
