I posted this in a previous running forum but it wouldn't allow me to post kept logging me out??? So here we are replacing a simple 35hp solenoid... cant figure where small white wire from the bottom left solenoid (small terminal) runs to??......... forgive me it's not the 1 i point at but the white 1 next to thatCan't really tell, but that sort of looks like a car solenoid. If it is, get rid of it and buy the right kind. There is a difference.
Ok every1!! I have a 35hp looks similar to all the replies but il post an additional pic. It appears to be factory starter solenoid on mine...
Twas replaced by a shade tree mechanic while he swapped my power head onto a different middlestack and lower(the seals and water pump gave out within the first year so here we are
I have a hot In from battery hot out to starter (2large lugs)
A red/yellow stripe also on a large lug.
A small white wire from small bottom left solenoid lug that is extremely short and the female round connector on it has a small hole opening that doesnt fit over the large lugs on solenoid (but the short length and wire memory appears it should go on left large solenoid lug) remember it did run fine until it didnt so I'm confused where this white wire goes? With my basic understanding of solenoids, I clamped it between the female connector on hot wire and the solenoid nuts so it was firmly held in place and it cranked right up??? In short how did the white small wire terminal fit onto the large power lug if the lug is bigger than the hollow in white connector??? Am I missing something?
