mickhodapp
Good morning all, i am in need of having these 3 questions answered please
#1- my motor gradually slowed down & then stopped peeing completely but is not hot to the touch so i replaced the impeller which had 3 cracked vanes but no pieces broken off. made no difference,water coming out of the exhaust but nothing from the pee tube. i then removed the two rubber water hoses which are open,ran a small plastic coated wire through the inlets but no debris so i thought that maybe it was the t-stat so i took the inlet manifold off & found that there was no t-stat in it So what next ? the motor is only warm to the touch after idling for 20 minutes.
#2- how do you remove the intake water screen,part #11 on boats.net ?
#3- On my motor the throttle plate has to be opened a tad to get air & will not start otherwise,but in the neutral position the arm on the shifter rod that stops the throttle plate from moving forward is riding tight on the throttle plate & will not let the throttle plate open far enough to get air so it will start so how do i adjust it?
