welshswampy
Evenin all, I'm repowering a 1988 24ft bayliner trophy from OMC to a GM V8 6.2 diesel with a 290 dp
The project is about 90% complete, just some wiring and a couple of hoses left to fit(and find some A3 props)
My questions are:-
Can I re-use the OMC trim pump with the 290 drive
If I can, does anyone know the size of the 2 male threaded domed fittings coming through the transom (the fittings that the hydraulic pipes from the rams connect on to) don't know the correct name sorry
Is the OMC pump strong enough to cope with the duoprops thrust whilst trimmed?
The OMC engine was 230 hp, the GM is 170
Also what are the advantages in using OEM props over Michigan, over here Michigan are priced around £400 and VP are £630 (big difference) are they worth the extra, or is the performance negligible
Any help much appreciated
Nick
My questions are:-
Nick
