Have a 2001 Honda 225 hp outboard. last month I heard grinding sounds coming from tilt and trim area. Asked the dealer who to told me to add some fluid. I did and the problem went away. however, periodically the tilt and trim would not move the engine (normal sound comes from the pump but motor doesn't move). I unscrewed the cap and heard a whoosh of air rush in as if it had a vapor lock. this went on and of for the next couple of weekends. Last weekend, I couldn't get the motor move at all (again, pump sounds like its working). dealer says I should spend $2k+ to get a new system installed. Any thoughts on what I should try ?
Also, motor is about 2/3 up right now. would like to lower it so that I could at least use it the remaining few weekends (live in Chicago area). Is there a manual relief valve that I could use to lower the motor ?
thanks
Scott
thanks
Scott
