Velvet Red
Just seeing if there are others that have had this experience. I have a 2021 Monterey with the 6.2 Bravo 3 2.20 sterndrive. At 54 hours I had a complete sterndrive failure due to a bearing according to the local dealer. It is quite a bite in the wallet as it is out of warranty and Mercruiser will not help. I’m replacing the entire assembly - upper and lower as metal from the bearing destroyed most of the internals and the case. The local dealer stated it was a bad bearing and I am still acquiring more information. I did buy the boat used from a dealer that was owned by an employees at the dealer and service records check out. I did not abuse or hit anything and put four hours on it and destroyed. When I took it it why we’re going to replace the cone clutch but noticed much more. The symptoms I experienced were it would not go into drive, if it is catch it would not move very fast at idle, just over idle the boat stumbled and slipped, upper RPM ran fine. I was told the linkage was out of adjustment which may have caused partial engagement and could have hurt the cone clutch. But then the bearing failure took all of this out. I had had the outdrive serviced about two weeks prior to the failure by an authorized dealer.
I’m very car engine and transmission knowledgeable but not with out drives but I am going to learn. Just hoping this is not a common experience. I take great care of everything I own and never have issues with anything as I am an over maintainer.
One reason I am posting is to get this logged on line in case others have had similar issues and we see a trend.
I’m a little soured and skittish but not going to let this drive me out of boating…yet.
