Below 3000 rpm the engine worked well. Above 3000 rpm the MIL light and a repeating alarm came on and the engine stopped. I could start immediately but the same thing happened if I went over 3000 rpm.
I found a similar issue but a broken link (Post of Aug 13, 2013) sent in by Isandboy123 but unfortunately the link was incomplete and therefore I don't have the solution.
I have cleaned the Low Pressure fuel filter, replaced the High Pressure Filter, which was filthy, drained the engine completely (vapour tube, fuel filters, raised and lowered engine while draining fuel, turned ignition on to drain more fuel). I have drained the fuel tanks, cut off the ends of the fuel lines to ensure no air leaks, filled with fresh fuel. Are there any needles that have sediment/particles and are plugging fuel delivery. checked the thermostat and it opens and closes when in hotwater and then removed. Installed a new Impeller service kit.
As well, I changed the oil and filter, new plugs, lower gear oil change.
The result is that now when I go over 3000 rpm, for example 3500 rpm, the rpms can drop to 2500 rpm and the either bounce back to 3500 rpm or return slowly to 3500 rpm. The engine is hot and has been placed in a large bucket. Only the acceleration handle is utilized to change rpm.
I feel confident that the fuel I purchased prior to the problem was contaminated.
Any suggestion would be appreciated. Tomorrow I will test the gas tanks for an air leak.
Cheers
Alex
Cheers
Alex
