Customer repowered in 2021. Has had problems off and on ever since. Think I was the fourth mechanic to look at the boat. When I got to the boat I found the lipstick broke off in the tube, and the distributor housing cracked where the cap screwed down. boat ran fine for about two months.
He said that the engine bogged down and after letting it sit for about 30 mins it ran fine back home. I found some oil in the bilge couldn't locate the source. So went on a sea trial and after 20 mins seen oil coming out of the dip stick and strb valve cover. Limped home and the strb valve train started making a lot of noise and never stopped. Went to pull the head and found a sheet of folded plastic under the intake, over the push rod seats.
now I'm worried that the crankcase had so much pressure it could have smoked cam or crank bearings..... has anyone seen anything like this in a crate engine before. How concerned should I be about the bearings? The noise while running sounded like it was all in the valve train. No oil I can imagine it sounding rough like that.
https://yourimageshare.com/ib/zNBIOn6NWU
https://yourimageshare.com/ib/VsxtkwIDvV
All thoughts welcomed.
