Don tknow where info came from but below is off Mercs website.....I'm looking at Mercury motor models and I'm seeing that the 75hp four stroke is listed with an RPM range of 4500-5500 and all of the other size motors, both smaller and larger, list 5000-6000 RPM.
| HP/Kw @ Prop | 75 / 56 |
| Fuel Induction System | 4 valves per cylinder, dual overhead cam (DOHC) |
| Full throttle RPM | 5000-6000 |
| 82 x 82mm |
75 EFI FourStroke Specifications
HP/Kw @ Prop 75 / 56
Fuel Induction System 4 valves per cylinder, dual overhead cam (DOHC)
Full throttle RPM 5000-6000
82 x 82mm
OK, so if I'm reading this correctly, I could feasably turn my engine into a 90 by changing the control unit?This will be long, and maybe a bit confusing, but- the 75 is exactly the same outboard as the 90 and 115. The only difference is the PCM calibration and the decals on the cowl. Usually, in an engine group like this, the easiest way to reduce hp is to re-map the fuel delivery programming, but in the case of the 75, Merc found that re-mapping alone would not reduce the hp enough to make the 75 hp threshold, without some kind of engine problem (they never did say what the problem was, but my guess was that by reducing fuel flow, a lean condition occurred- just a guess). In order to still have an outboard in the 75hp class, the easiest way to lower maximum hp is to lower maximum rpms. The reasoning behind the hp grouping is economics- every manufacturer wants to have an outboard for every boat made, and it's a whole lot cheaper to make one outboard and "de-tune" it than it is to make 3 separate outboard models.
Oh, and Jeff- about the lifespan of high revving fourstrokes: I have a 2006 60 EFI that has 1150 hrs, and runs 5900-5950 rpms WOT, and I run at WOT a lot. Still have 140-150 psi compression across the board, no engine problems, and no noticeable power loss. (a couple of gearcase problems, but those where impact related.)The new stuff will definitely take high revs and last. As an example, I drive the wifes' Nissan Sentra once in a while, and it scares the bejeezus out of me when the tach hits 7 grand, but it doesn't seem to hurt it any.
That might be a thought for after the warranty runs out. Now, can I change the prop and run it a 5900 rmp without damaging the engine or will it set off the over rev alarm?Yup, as long as you have $850 for a new ECU / PCM, and another cupla hundred for a new prop.
Any way to get around it?The rev limiter will activate at about 150 rpms over recommended WOT (5650 rpm). The guardian system will kick in, the alarm will go off, and the outboard will drop rpms by dropping spark to 1 or 2 cylinders. Very, very annoying.
I did somr further checking into the motor and they didn't change the camshaft. They de-tuned the motor with the control module and a restrictor plate but the motor was still a little over the 75hp range, so the lowered the max RPM to get it to fall into specs.If I am correct (hah!) raising the rpms won't help IF the camshaft is made milder to lower the hp.
Jeff
