Hi folks. Have a 2007 15HP on an RIB inflatable that has been sitting for 4 years. Fuel had been drained, fogged, oil changed. Will fire/run for a second or two (but only with the choke partly open, then die. Was able to get it started finally by giving it throttle right away, pushed the RIB with it. Could not get it to full RPM/power, and it would die at idle.
Removed carburetor today and disassembled/cleaned/lightly blew out with compressed air. I do not fully understand the operation of all the carb bits, but I followed the shop manual. The old fuel remnants had dried to a varnish, it was pretty messy in there. Put it all back together and it will fire/run for a second or two consistently now, but I could not get it to run at all. When I try to give it throttle when it fires/runs, it bogs down and dies. Worse than before somehow.
Would really appreciate any help/thoughts. Pretty frustrated.
Thanks.
Thanks.
