Ok I have a 2006 BF50A Honda tiller carbed. I recently had a teleflex tach with hour meter installed. I have it on the 3p 6c setting which is what teleflex recommends. I have tried 3 different props and the most rpms I can get on the tach is 4400, however, I am running 36 mph(confirmed with 2 gps's) and the motor sounds like it is turning up well past 4400...but not hitting rev limiter.This is with a 10.3" diameter 4 blade, 10" pitch. Boat is a 18' flat bottom aluminum hull.
I have tried all 6 different tach settings and all the others are even further away from possible. Teleflex said there was a module to help with bad tach readings on the hondas but it was for 2005 and earlier models...?
Any advice would be greatly appreciated. Thanks
