I am new to this forum,but not new to Honda's, purchased a 1989 Crestliner Sabre last September with the Honda 150hp 25" shaft ,jacked it up & trim tabs to get bow down ,I ran it with new 4 blade prop to max rpms at 6000 rpms to find out its wrong pitch,1st time i heard this high pitch whine noise, couldn't see any lights ,oil is full ,peeing water ok, not as strong as it was when first got it though, and clean ,but noise wouldn't stop even at idle even after i turned key off, had to turn the battery switch off to kill it. i videoed the noise and sent it to a marine mechanic friend, i thought it might be the VST fuel pump or the Relay or ECM, what it sounds like is the over heat alarm, really high pitch whine, got video but can't upload it here, it only alarms whne i am going over 4000 rpms and when its hot,i have radar heat gun but it doesn't sound on idle/hose flusher, no hose port on engine just undue the hose on starboard side, any clues helpful, going to try to reverse flush out the exhaust from top thermostat with hose jet & salt x, will check out the lower screens for obstructions,, if there was anyway to text the video of the motor whining it would help. Also i hear there 2 thermostats 50 &60 degrees, 60 on block 50 on the top ,but it looks like there 2 under the top cover? Can't find spot on the block looking at the schematics, trying to locate right parts to replace after back flushing motor
