The tilt trim assembly on my BF50A has started making unusual grinding noise this past week, when it is raising the motor. I checked the fluid and it was low, so I added ATF to top it off according to the service manual. I noticed a leak at the housing seam of the main cylinder where the case bolts together. The bolts are tight, but there is fluid seeping out when the unit is raising and lowering (no cracks in the casing).
I bought the boat last year and use it weekly, and it has always had a slow leak-down which causes the motor to lower about half way over the course of about a weeks time. I did verify that the manual release was not the problem. I opened and closed it several times and it works properly as far as I can tell. I suspect there is a small leak from one of the internal valves/o-rings, allowing the pump system to leak down over time.
I am now considering replacing the tilt trim assembly since I have two problems, with the internal grinding noise being a major concern now. So, my questions are:
1. Where can I get a new power assist tilt trim (56000-ZW4-H17 TRIM-TILT ASSY., POWER) for a good price?
2. Are there any compatibility issues that I will encounter/should consider when ordering the new assembly?
3. Are there any other items that I should also order and replace when replacing the tilt trim assembly?
Any help is greatly appreciated.
Thanks in advance.
Don
Thanks in advance.
Don
