Hello,
First post and a new boater, so thanks for your help!
I have had this motor for about 4 months. Had it serviced right after getting it, carb cleaned and overall inspection. Took it out twice and then the impeller blew (I think boat was sitting for awhile before I got it). Took it to a different mechanic and had impeller replaced, oil changed (both top and bottom), and carb cleaned again (he said it was dirty). Took it out and worked good. It was still really hard to start when motor was cold, several pulls to even get it to turn over, and then several more where it would stall out if any gas was given, after 5-10 minutes of this it's warmed up and goes.
Then took it out for second time after the second service, still hard to start, but once going was doing real well. Then we were about 8 miles out and it just died all of the sudden and would not restart. Finally got it to start after about 10 minutes, but it would only idle with the choke out a bit and die with any gas given or putting the choke in. Then another 10 minutes or so, letting it idle as much as it would and giving it gas as it would allow, was able to get it in gear and go with the choke out about 10-20%.
Everyone is telling me the carb, but it's now been cleaned twice with only 2 runs between cleanings.
After reading posts here, I have replaced the fuel filter, emptied the fuel chamber (between fuel pump and carb), replaced spark plugs, and drained the carb.
Things noticed when doing those things:
1. I tested the fuel pump by pulling starter cord with the fuel line detached from fuel chamber, when pulling the cord very little fuel was coming out of the pump (teaspoon or two maybe) compared to what would come out when squeezing the bulb. Not sure if this is a good way to test.
2. I collected fuel from each step to examine (i.e, before fuel filter, after filter, after pump, after fuel chamber, from carb drain). The fuel from tank up to and after fuel filter was fine. From pump and chamber (already emptied and reinstalled) it did have a substance at the bottom, hard to tell if it's water or oil (looked like oil in color and movement). From carb drain same substance, and some small "flakes" which surprised me as well since it's now been cleaned twice and hardly used.
Need help! Did I get a lemon of a motor?
