2005 Mercury 115 four stroke relay switch
BogieRCF
I need to change out the trim relay switches on the motor. Any suggestions as to where they are located? Must be hidden behind something Thanks
It doesn't have separate relays, it has a relay pack like below. If up is not working check the limit switch
The trim always works first time in down position. If I click the switch in the up position multiple times , so far the trim will randomly work and raise the motor.
Do you think this could be the limit switch?
Thanks for your help on this!!
That Mercury model was made by Yamaha. Uses a Yamaha trim/tilt relay assembly versus two separate relays.
Mercury offers a kit to convert it to the Mercury style of relays. Also available from BD Electrical.
