2005 Honda 225 #5 Fuse problem
Jeremy3030
Fuse is popping every time we turn the key on, engine will still crank and run at full speed, alarm sounds and no lights come on
any suggestions?
Don't have my shop manual with me, but if I recall correctly, the #5 fuse powers a lot of stuff. Try to find a copy of the wiring diagram. In SOME owners manuals it's in the back of the manual. My first instinct would be to pull the fuse box and make sure there is not a broken wire from the fuse that would be grounding out.
I had the same problem. It ended up being a short in the fuse panel in the engine yellow wire. Needed a new small fuse panel harness then a wire harness from the engine to the condole. $2500 later. All fixed
