Just bought a boat with twin BF225. Before I put her into the water, I have a mechanic went through them and replaced the following items:
New batteries
Parker fuel water separators
Low pressure fuel filters
VST filters
HP fuel pump at the starboard motor
full clean up the VST on starboard motor
New spark plugs
Clean the fuel tank vents
Those are my first 4 stroke engines, so I don't know if this is normal or not. It would take 7 to 8 crank to get those motor started when cold. Hot start is easier.
Mu biggest problem is both engine won't go over 4200 rpm under load. I have checked the IAB valves and they seemed to move freely. There is no faulty code, no MIL light, and the engines run smoothly from Idle to 4200 rpm and can stay @ 4200 rpm for hours. The throttle cable on the starboard motor travels a bit less than the one on the port side, both side have some slacks but I don't think it is the root of the problem. This boat has independent fuel system for each motor, and I just put 80 gal of fresh fuel on each side. The motors did not sound like starving, no surging at all.
I am wondering how can I tell if these engines have service bulletin #56 done? I notice that, after a long cruise and then pulling into idle, I can see steam coming out briefly from the the exhaust pipe on the port engine, but not on the starboard side. Does this mean there is water intrusion on the port side?
Sorry for the long post and appreciate any comment and suggestion.
Thanks.
New batteries
VST filters
New spark plugs
Thanks.
