islandwoman
Let me start by saying that I'm a woman with no mechanical background but I am good with my hands. So go easy on me if I use the wrong terms. There are no honda mechanics around us so I'd like to try to help my husband fix this issue. We bought a 21' flats cat with this 2005 BF135 on it in June of 2022 from a dealer that had just done a lot of work to this motor and had it in running condition at the time of purchase. Last time the hours were checked at that time, it had 250 hrs on it. We estimate that we could not have put more than another 50 hours on it so this motor has maybe 300 hours on it max. So we're speaking about a fairly fresh motor here... Only been used on saltwater though... In May of 2022 the marine dealer we bought the boat from had done the following work to the bf135 in question: "Changed engine oil and filter. Replaced in-line fuel filter and water seperator filter. R&R gear case and replaced water pump impeller and changed gear lube. Replaced spark plugs. Replaced bilge pump. R&R thermostats and clean, replaced thermostat housing and gasket. R&R vapor separator tank, clean out and replaced fuel pump. Replaced oil filter. R&R fuel injector and sent out for clean and flow test." We used it maybe 4 times and from the first use we had that surging problem that everyone talks about but it would idle fine. My husband thought that it needed to work through the issue by running the motor out. Fast forward to now. The motor will on crank and will start for a few seconds when squirted with starter fluid but it will fail to ever reach an idle state. I checked the code by using a service connector shunting device and the MIL just stays on. Doesn't blink at all. Lead me to believe that the ECM was bad so I bought a known good one and swapped them out. Same problem as before and MIL still just stays on when looking for codes. So that has lead me back to believe that maybe there is a short to the MIL and that we should focus on the obvious symptoms. The motor isn't getting fuel. Given that it just had the fuel system cleared by a mechanic, I am not sure what could be wrong. It acts fuel starved. From the first time we ran it after all these repairs were done it would go into an almost limp mode but would always be able to get us back to the dock. It will not start at all now. Help!
