2005 15hp won't start on it's own
EVIL-MK
I have a 05-06 15hp that does not want to start up on it' own. If you spray a shot of starting fluid in it, she will fire right up & stay running. I have rebuilt the carb, put a new
fule filter in it, checked all the hoses for leaks, & replaced carb & air box gaskets. Still no go, any ideas would be greatly appreachated. Thanks
Re: 15hp won't start on it's own
Obviously a problem with the choke / primer set-up. What model is this motor ??--------Electric start or manual.-----------Have you verified operation of choke / primer unit if equiped
Looks like an 04 model--------------Check out the parts break down on -------boats.net ------------Item #13 is the automatic starter / choke or primer unit. Check and see if it works.
Howdy,
The automatic enrichment valve or "bystarter assembly" (as Honda calls it) COULD be stuck but I've never seen one fail in almost six years. The valve is defaulted in the START (retracted) position and is then extended against spring pressure as the engine runs and charges. If it were to fail electrically, it would allow easy starting but then would cause the engine to bog on a rich mix. Exactly the opposite of your problem. You can check it's operation by removing it and applying 12vdc to the plug terminals and verifying that it slowly extends after about a minute and then slowly retracts as it cools down after the current is taken away.
My guess is that you will find it working ok. My guess is that your carb still has dirt in it somewhere.
You have to take the carb off to check the bystarter anyway so disassemble the carb again and look really hard at all the circuits. Find the accelerator circuit in the main body, prop the throttle plate wide open and spray carb spray into the accel pump passage and verify that about a 4FT. stream of spray exits at the rear of the carb.
Take the JET SET out and, using the plastic straw that came with the can, insert it into the passage at the top of the carb throat and verify that all three orifices at the top of the throttle bore are "gushing". Closely examine the drilled portions of the jet set tube as well as the interior "tunnelway" and make sure you see light. That tube can be clogged by some pretty tiny particles.
The only real way to properly clear the idle circuit passage ( orifice on the engine side of the closed throttle plate) is to remove the idle mix screw and back flush several times. This may be your problem area as the engine starts and runs after an ENGINE KILLING spray of ETHER. As a mechanic, I HATE that stuff! Should only be used if you're SINKING. I digress.
Getting the idle screw out usually requires that you break the screw head to get the limiter off so you should have a new one on hand before you start. Sometimes you can heat the limiter cap with a soldering iron and get the screw out without breaking it though.
If you re-used the oring at the top of the JET SET tube, bAAAAAd. Always use a new one there and re-install with a coat of WD-40 and much care. That is a critical junction.
If you don't regularly drain your carb USING THE DRAIN SCREW provided for that purpose, you passages in the bottom of the float chamber may be plugged. Study them and make sure they are open and will pass a shot of carb spray through the "tunnel" easily.
If you do all this, that puppy will start right up after you bolt her back on.
Good luck,
jimmyd
One thing I was reminded of on this engine is that it has a sort of water separator attached to the dipstick tube. Honda calls it a "fuel chamber". See item 2 on the parts link page below.
http://www.boats.net/parts/search/H...-1200001 TO BALJ-1299999/FUEL PUMP/parts.html
Before you do anything else, take that thing completely off and drain any liquid that is in there. It should be routinely pulled off and drained anytime you have any running issues as it can retain water and contaminates. There may also be a recall on that item for a free upgrade. You should check that out if you haven't already. Use the link below.
http://marine.honda.com/owners/recalls
jimmyd
