2004 Johnson BRP 175HP model J175PLSRB no spark on any cylinder
Spark testing: done w/ ignition safety clip attached to ignition key switch, done again
w/ the ignition safety switchs black w/ yellow tracer disconnected at engine.
What I have done is insert a bulb type spark detector inbetween the spark an spark plug wire, then using my mometary ignition connected to the starters group of red wires to side of starter an the ignition hot wire yellow w/ red tracer at bottom of starter to bump the starter this w/ the ignition key switch on,didn’t see the bulb lite-up on any of the 6 spark plugs.repeated test w/ key off.result no spark.
Coil testing:
Then tested the coils from where the spark plug wire attaches to an where the power pack connects (small terminal)result was 290OHMs -299OHMs on each coil.
Next coil test was from where coil mounts an grounds to block to spark plug terminal
Result 0 OHMs.
Additionally the coils appear clean no leaking of glue an no burn marks.
spark plug wire testing:
My multimeter has a continuity tester that beeps however it never beeped.
I tested all spark plug wires for resistance all where .6OHMs -.45OHMs
all wiring appears corrosion free. as doe's where the coils bolt to block no corrosion.
Comments on engine:
I’ve had this engine for 9 years baisely trouble free. Haven’t used it for the last 3 years. I winterized her (fogging cylinders an running the engine till all fuel was burned from carbs bowls). So this no spark is the first ignition related issue I’ve had.
Except for about 7 years ago the spark was very weak she still ran but weak.
I was down at the Gulf stopped by a dealership they knew me from previous engine purchase.
the mechanic knew right away what the problem was he used a small impact
IIRC the flywheel wasn’t removed but the I think it’s the timing cover.
I believe he swapped the optical sensor took him 15minutes, shes been fine until now.
Removing the flywheel mite be to much for me to handle then putting everything back w/out messing up timing carb idel wot setting ect.
Coil testing:
Result 0 OHMs.
Comments on engine:
