Ok, I had my engine worked on by Honda tech, he replaced my leaky shift seal and that problem was fixed. But since he worked in that area my batteries are not charging. When he left we only ran it for <10 minutes at the dock and I did not have any electronics on.
I'd like to know the best way to troubleshoot this.
I did a visual inspection of the connectors and nothing appeared to be "Not Secured". I wiggle the connections to see if the it would vary the voltage nothing.
The motor starts and runs fine, just not charging. See photo of when he replaced my Shift seal, he had to peal back the associated cabling harness and unplug various connections.
I have two independent batteries on an A/B switch and select to run them independently, neither one appears to be charging when the motor is running.
If I remove the connection to the alternator (remove the load) to measure the output, will this create a problem since there will be no load on it?
