autowerx123
I have 2004 Crest pontoon with a 2004 Honda BF 115 that just started beeping while out on the lake this past weekend. The oil is full and I have a good pee stream. While out this past weekend I was on the water maybe 20 mins and it started beeping. The boat was running great when it started. I turn the engine off immediately and started investigating. I made my way back to the boat ramp with no trouble. When I got home I checked the water seperator and the fuel filter and both were clean and no signs of water( red ring on the bottom of the separator). I hooked the hose up and started the engine and started unplugging sensors. One of sensors above the fuses killed the engine when I disconnected it and the beeping stopped. Plug it back up and the beeping starts back. It's about a one second beep off and on. I traced the wire down to a fat wire loom that is taped up. It runs down the front of the engine. I took a picture in case any of you know what it is off the top of your head. I don't know what else to check and any help would be greatly appreciated. Thank you!
