Thanks for the reply jgmo. I'll give some more details.
First, the boat gets very little use, maybe three trips a season. It has no running issues, and usually starts very quickly, within a few revolutions. The problem first started last spring after it had been sitting for the winter. I usually drain the carbs when I know it will be sitting a while and when winterizing. The long cranking periods were only at first start up after winter getting gas to all the carbs and on a couple of very cold mornings.
The batteries were six or seven years old and I made the assumption that sitting over the winter might have done them in. I got new batteries, but the problem still happened when switched to either one. I only used the boat one other time during the summer, but since it was warm, the boat would start normally on only a couple of cranks.
Getting it ready this week, I decided to crank on it before putting gas in it to see if it would act up. After four or five cranks of maybe ten seconds, it started to hesitate and couldn't turn the motor over. It also heated the grounding wire from the midsection to the transom bracket, so evidently that current can't get back to ground the way it should. I'll get to work later this week and check the connections under load and try to find the problem. Thanks
