Boattechlm
Hi, I have a BF115 2004 model EFI. Motor tries to start but will not stay running. Fuel is good, motor has good compression and spark. I can hear the fuel pump running when key is turned on and I am getting fuel to the VST. I also took the fuel rail loose and removed one of the injectors and turned the key on and was getting fuel pressure at the rail. Put it back together and it starts and dies. Runs maybe 2 seconds .
i pulled what appeared to be the return fuel line, comes off the pressure regulator. No fuel coming back.
not sure what is wrong or what to check next. Engine oil looks good. Motor was running fine 2 weeks ago.
when I first checked motor fuel pump would not run.
I lost 12v to fuel pump due to a bad relay . I replaced with a new one and I also disassembled VST and cleaned it and replaced the screen , o'rings and filter and fuel pump. Now I have problem described above.
thanks for any help.
