BurntGreene
Hi, I am looking for some help in diagnosing a problem with my inboard. I have had the boat for 3 seasons, and we live in a 4 season climate so we do winterize our boat and store it at the marina that we rent a slip from. They also happen to be certified Mercury mechanics. The first year we owned the boat, it ran great and was super reliable..... no issues. The second year, the boat started to pop, sputter and loose power after about 45 minutes of use. I could bring the boat down to an idle and make it back to the marina most times but I did have to be towed once and it sucked. The marina mechanic would test drive the boat and not be able to recreate the issue, so we started replacing parts that "could be responsible" for the boat acting like it did. Each time we replaced a part, I would take the boat back out and the engine would start popping and sputtering again. The marina could never recreate the issue, I suspect because he would not drive the boat long enough or not get the engine hot enough. Eventually the boat did act up while he was in the boat with me. Here is a list of what was replaced before the mechanic heard the problem: 1. Rebuild the carb 2. new distributor cap and rotor 3. new plugs After the mechanic heard the issue, he felt that the engine was making the sound from the back of the engine and suggested this part: 4. new distributor module under the distrubutor (I think it affects the timing) I need help..... any feedback would be appreciated.
