My motor has become hard to start after running to a fishing location. Now i'm getting a pop thru the exhuast while running above 1500 rpm. A mechanic told me I have leak on the stbd side intake. I disassembled the motor and the only problem I found was the lower bolts on the throttle plate and intake were lose and the port rubber hose on the port side is not connected to anything. The stbd side connects to a fitting at the lower part of teh power head.
What are the balance tubes used for and where does this hose connect?
