We have a Honda Bf200 on a 26' Apache Sea Master Deck boat. When we first got the boat 8 years ago we would hit speeds of 35MPH. Now presently we can only go 20 MPH. When we have 1-2 people on the boat the Tach reaches 4400 but when we have more people on it the Tach goes up to 6200. With 1-2 people we go 20 MPH with 6-10 people we go 16MPH. You can actually hear the difference in the motor when the tach goes up to the 6200. We have replaced the following, Plugs, Both high and low Fuel Filters, TPS. Fuel Pump. Fuel Regulator. Cleaned screens on bottom of high pressure fuel filter, Throttle Cables(adjusted so fully open when fully engaged). Removed fuel injectors and had them cleaned. Check compression all cylinders good. Motor runs clean and smooth. We run the same size prop as we always have 15 x17. Motor has 780 hours on it. Bought a Dr. Honda Diagnostic kit and it has no codes. What are we missing. Thanks
