bill_black
I have a 2003 Bf90, 1600 hrs, fresh water. I prepped the boat as usual to launch this year, including impeller, oil change etc... all the usual. ran if for 5 min on muffs and all was well.....just as it has been for the past 20 yrs I've owned it. It has never burned (any measurable) or leaked any oil. Anyway, I launched it and within 15 minutes of idling I got my first ever oil alert. I shut it down and took the cowl off - full of oil all around the base of the engine. Probable 2 quarts dumped in there. I was hoping I did something stupid when I changed the oil filter but no-dice, didn't appear to be leaking from an improperly installed filter.
So here I am doing a bit of research to see if there's anything easy I can check. My gut (and experience) tell me it's probably some seal or gasket that failed and a major undertaking is necessary to get to the root of it.
Two questions: 1. anything easy I can check? 2. What do you think is/are the most likely culprit(s)?
This leak came on suddenly. No leak for 5 min on muffs..........dumped everything after 15 min idling in the water.
Thanks in advance.
Thanks in advance.
