Recently brought my boat into the shop to fix an oil leak, which I assumed to be shift shaft seals, big job so I figured a professional was in order. It ended up being a crack in the case, so had that replaced along with seal, exhaust tubes, shift shaft, fuel filters (high and low pressure), water pump and a few miscellaneous things. Got it back, after 2months and just took it out, and got 100yrds and it stalled out, pumped primer got ut running for a minute but not consistently. Needless to say, after spending a ton of money im very frustrated. I can take it back to them, but at an hr and 45min each way and pretty much a certainty it would be the end of my season here in the north east. I assume its directly related to the work done as it ran beautiful before, I have fuel running freely to the exit side of the primer bulb and thats as far as I got there, also took water seperator apart everything moves freely and continuty reads as it should with float in up/down position, gonna work on it all day tomorrow (instead of fishing) so any insight you guys can give me is definitely appreciated. Also fuel doesnt seem to be filling much in the low pressure filter maybe 3/4" or so, not sure if thats normal. Thanks guys
