"I have an 03 BF 225 with 200 hrs on it, I had let it sit for two months as I was tied up with work, when I made it down to start it, It wouldn't run at all. Short version, had a bad HP fuel pump. Replaced the HP fuel pump and While I was under the intake I replaced all the injectors, and the LP fuel pump as well. Motor has new plugs and fresh oil. It will now start and run and I can pick it up off idle, but after about 2 mins it sounds like it is starting to starve for fuel and cuts out. I am currently running off a test tank to eliminate any tank issues, I have even connected the tank directly to the LP fuel pump. any ideas??"
