Hi All,
I have a 2002 Johnson 115 that I am having issues with. The motor will surge at high RPMs while underway and eventually bog down. When starting it up it is rough and often stalls when shifting it into gear. In addition, the motor smokes like a chimney and dumps far too much raw fuel out of the exhaust.
So far what I have done on the motor is the following:
Compression check (all four cylinders good and even), checked for spark, brand new 3/8’’ fuel line, new ball, new racor 30gph fuel water separator, new fuel pickup from original polyurethane tank, fresh gas. A few months back a mechanic friend of ours replaced the VRO fuel pump, it was not running prior to that for a few months and this was deemed to be the culprit. Now with everything from the fuel pickup to the VRO Fuel pump being brand new, it is still far from running properly and I have thrown $1500 in parts alone into it.
In addition to these parts, I removed the intake manifold to spray out the screens and check valves, disassembled the carbs and sprayed them with no apparent issues. I am at a crossroads because the outboard mechanic I took it to for the compression and spark check tells me it is most likely a bad fuel pump hence the excess smoke and the engine acting like it is either starving for fuel at high speeds or running way too rich at idol. I was planning on either A) disassembling the VRO as much as possible to check for any issues (cheapest 1sr step) B) Purchase the carb rebuild kits, replace all gaskets as well as the check vales within the intake manifolds which would amount to about $350 in parts, or C) which would be to replace the VRO Pump for the second time, $400+++. (too much time has lapsed to try to get a new one from the original replacement vendor).
All mechanics and forums say to run the boat off an external tank however as mentioned above, everything in the fuel system is new so I can seem to make sense of spending $50 on a 5 gal tank when there should not be any issues between the tank and the fuel pump.
Any suggestions are appreciated!
