I have a 2002 BF225 with 353 hours, had the unit on the engine stand for about a year while I dry docked boat to replace stringers, transom, floor, etc installed the motor about 3 weeks ago and have been re-doing boat electrical since then, (replacing some corroded wires, re-routing etc) not the engine harness whatsoever, tried to start it up, won't start, troubleshot engine, found hi-press fuel pump not working, removed it, benched it still not working, bought new pump benched it before installing, new pump is good, installed it, still not working, only have 2.5V going to the pump, decided to replace main relay, still not working, still only 2.5V, checked all ground connections and cleaned corroded ones (very minimal) still only getting 2.5V, does the ECM have any control on this voltage drop or is it in the harness somewhere?
