Richard Powajbo
Guys, I've read all the forums on related issues and still not sure of my problem. Please help. I have a 2002 Honda 225 Serial Number BAGJ1000479. I'm the original owner. From time to time I get an aggravating alarm. The overheat indicator lights up red and the motor goes into protect mode (dropping the rpm's and running rough). Water pump is pumping and water pressure is good. Water pump and thermostats are changed every 2 years. Currently have 650 hours. Been to two dealers and neither one can completely fix the problem. At 74 hours the ECM was replaced. At 133 hours, the O2 sensor was changed. Both repairs covered under warranty, but the problem still exists. When the alarm goes off, I used to turn the key off and restart. The problem went away temporarily. My latest dealer told me to let it run to see what happens. He said I was clearing the codes when I turned it off. After a short while running with the alarm on, the problem goes away. He checked the codes again and still nothing stored to pinpoint the problem. It happens more frequently in the winter when it's cold. It used to alarm once every 8- 10 trips. Second to last trip ago, the alarm went off 5- 6 times. The last trip, it ran perfectly with no alarms at all. Could the O2 sensor or ECM be bad again? Not sure if it was ever the problem or not. It appears that I don't have any issues with water entering through the exhaust ports (I've read those forums too). Another local Mechanic is telling me that it's the ECM. He's saying while in protect mode, the engine should turn off. He loaned me another ECM to try, but the part number is not exactly the same. My ECM is 3450-ZY3-013. The loaner is 3450-ZY3-A01. Was hesitant to try it since the part number is different. Is it ok to run this on my motor? Any suggestions or advice will be appreciated. Overall, my motor has been excellent except for this nuisance problem.
