ChuxCaliber
I have about 1000hrs on motors. Last trip out noticed the gauges weren't working on port motor, but it started and ran good. There is a bottom finder and gps connected to the port battery with a volt indicator on the display. Good charging voltage indicated all day on the port battery. When home from trip tried to flush motor and the gauges still didn't work but this attempt revealed the familiar starting beep was gone and the motor would not start. In fact the starter won't engage. I replaced the starter switch but that didn't help. Checked fuses (I am aware of), checked for wiring problems under helms station, didn't find anything. I'm thinking a problem in the motor. Any suggestions? Thank you in advance for you reply, Chuck
