Stressfree
My alarm goes off when key is turned on book says unplug heat sensor if alarm stays on move on.book says bad alarm relay or grounded out wire.any ideas
The magnet inside the oil tank wasn't one of Mercury's finer moments. I had mine fall off last outing and I'm not going to saw my oil tank in half and attempt to satisfactorily glue it back together to get at it......sometimes the cure is worse than the cause. I have a reminder to check the tank oil after each outing.
I just watched the video on YouTubeI was able to re glue my magnet back onto float. I made tools out of rod to pull spring washer off. Cleaned and JB weld mag. Been working for 4 years.
If I got a new tank does the switch come with it or do I reuse the old oneI just watched the video on YouTube
