My 2002 5L Merc has a popping sound at approx 3k RPM , I have has the coil, pugs , cables , water pump and computer changed or swapped with the starboard motor.
Timing has been done as well along with adjustments to airflow to the Carb. When adjusting the timing the backfiring happens at a lower RPM. Fuel is good and is new .
The vacuum hose squeals and pushes out air??
Any thoughts on why this is happening
