BackEastDon
I signed up for this forum a while back to search through stuck valve issues. A boat I am under contract to purchase ended up with a stuck valve in one cylider from water intrusion that was discovered commissioning the boat this spring. Engine is a 2002 5.0L 2bbl. The head was removed and reconditioned at a reputable marine machine shop (according to the surveyor). We've reviewed the work order and parts invoices and all looks done properly with new head bolts, risers, manifolds and such. The intake manifold was inspected and pressure tested as well. The engine work other than machine shop was performed by the sellers son who is ASE GM certified.
During the survey the engine compression test measured 185-190 across all cylinders. Rest of boat is clean, dry and solid. There is always a but. During the seatrial the engine combustion intermittently was popping through the carb at 4200 rpm. The surveyor suspected the valves were set a bit too tight. It otherwise starts and runs smooth. I am awaiting the seller to get the issue resolved and will go out on a second trial.
Would appreciate some insight from those more familiar with this engine. Last pushrod V8 I did heads on was a 69 Chrysler (many, many years ago).
Thoughts? Advice?
Thoughts? Advice?
