Looking for some help. I recently purchased a 1999 World Cat with twin 2002 200hp Hondas on it. Motors have been running great until one started alarming and going into Limp mode. Checked plugs found plug in good shape but replaced anyway. Found one of the seals in the valve cover leaking oil filling up the area around coil pack, replaced seals. No water infiltration into the oil. Replaced impeller and thermostats motor runs great for maybe 5 minutes to 20 minutes does it at speed or or idling, but will alarm and go into limp mode but all I have to do to clear is turn it off and restart and may go another 20 minutes before it does it again. No rhyme or reason or consistency to it.
Watched all the videos on line about installing jumper into the red connector shorting out the lime\green wire and the black to get the dash lights to flash a code. My light just comes on and does not flash?
Do I need to catch it in alarm and install the jumper? Seems like the alarm is clearing on restart or is just not working.
Any thoughts would be appreciated.
